Hi all
Looking for a way forward. I am currently looking at converting my old kitchen into an office and need a heating solution, looks like a solid concrete floor so not much chance of being able to install a radiator in there without it becoming a real pain.
So, radiator is out.
Underfloor electric heating is possible but expensive (apparently) to run.
Can put in a oil radiator as these are reasonably cheap to run.
I will be putting in 70mm celotex on the inside which should keep the heat in as i have some left over from the extension.
I've seen a couple of wall mounted ceramic heaters which seem to have good reviews but i guess will be expensive to run too.
You can buy oil filled rads now which look like they just plug in, that might be a decent solution?
Not too sure which way to jump on this one
