Hi, as you can tell from the name, my DIY skills stop at putting together flat-pack furniture.
We have had a local plumber/electrician (single tradesman, both trades) re-wire and re-plumb the kitchen. He initially installed a 3-pin plug hole for the cooker hood to be plugged into; however we pointed out the installation instructions which stated "this appliance is fitted with a 3 core mains cable and must be permanently connected to the electricity supply via a double-pole switch having 3mm minimum contact gap on each pole. A Switched Fuse Connection Unit to BS1363 Part 4, fitted with a 5amp time-delay fuse, is arecommended mains supply connection accessory...."
He disputed the need for this, arguing that the circuit was protected by the RCD Protected Circuit Breaker Box. I insisted that a 3 pin socket was not good enough and he has been back in today and fitted what to me looks like a normal lightswitch. His advice to my wife was that, once I have put the extractor fan up (it can't go up at the moment because it mounts between 2 cabinets which have yet to be put up because he is doing the wiring), I can simply knock out the blank in the bottom edge of the switch and attach the wires. He reassured my wife that this act did not require a Part P qualification.
This all sounds highly dubious to me! Any advice would be gratefully received.
If it is confirmed that all is OK and that I am being wet, I would be grateful for advice on how to wire in the "3 core mains cable" (see above quote from the manual) into the switch whilst also adhering to the other warning in the instructions "Warning: Double Insulated Do Not Earth"
