Laminate Flooring Recommendations
22 Aug 2005
Bournemouth
Hi there,
i'm planning to lay Laminate flooring though my hallway and downstairs cloakroom, and running into my dining room at the back of the house.
I just wondered if anyone had any good recommendations of the stuff i should be buying. I like the idea of a 'click' system as i have layed this in a small room in the past. I don't want anything too expensive just 'middle of the road'. I don't mind ordering off the internet but its quite nice to be able to see what you're getting first.
Also what is the best underlay to use. I have some of the 7mm 'woodchip' type tiles from B&Q, but i could easily take that back.
All advice would be gratefully appreciated.
That's the 'widest' question you can ask :D
In the end it's down to personal taste, budget and DIY-skills.
Consercing your underlayment, that depents on the kind and the quality of underfloor you have: floorboards, sheet material, concrete/screed?
7mm underlayment is quite high and could make your floor 'bounce', specially when you use thin Melamine Laminated flooring (8mm total thickness).
