Hello
I recently had a laminate worktop fitted with butt joints at corners. When this was done, the builder used glue for the butt joint. He did not use colorfill. After the pieces were joint together, there was a small visible gap (i.e. not flush!) and at this point he used colorfill to fill the gap. The problem is that the colorfill has not adhered well and keeps pealing away, and repeated filling on my behalf is making no difference and I am worried water will get in and the worktop will bubble. Can I simply apply a bead of clear silicon on TOP OF the existing colorfill to prevent any problems.... or are there any other solutions?
