I want to put up a new landing light about a foot or so away from where its predecessor's ceiling rose was and have a dilemma as to the best way to reconnect power as the switch cable is too short for this new position and I also don't have a huge amount of slack on the light fitting's cable coming up through to the loft either (L,N,E and extra earth as metal light).
As it's in the loop I have power in and out (both these have enough slack), the switch cable and then obviously the cable from my light. I guess replacing the cable from the switch would be the best option, however what's the next best alternative?
Extend the switch cable and bring that to a junction box to put all the connections into?
Extend the light fitting with some choc block and bring that over with the other two cables to the switch cable and connect in JB?
Any other options???
Finally, regarding junction boxes, I've read many forum entries about securing to joists and putting the insulation over the top but also leaving the cables on top of the insulation is advised. Are both ok? What does it depend on?
