Lath and Plaster Replacing with drywalll
Discussion in 'Plastering and Rendering' started by deanflyer, 13 Jul 2008.
  1. deanflyer
    deanflyer
    29 Jun 2008
    14
    Thanks Received:
    Tyne and Wear
    Country:
    Have a 4x4 ft section of wall where the plaster is all but detached from the laths. Is the best way to replace this just cut thelaths,batten and replace with drywall?
    Any hints/gotchas?
    Dean
  2. jbonding
    jbonding
    4 Feb 2005
    1,926
    Thanks Received:
    2
    Manchester
    Country:
    cut it out back to the studs and re board with plasterboard, check the thickness and get the apropiate board or double up ie 9.5 * 2 =19mm and then just skim taping the joint.
  3. Sponsored Links
  4. deanflyer
    deanflyer
    29 Jun 2008
    14
    Thanks Received:
    Tyne and Wear
    Country:
    I have cut it back to the studs, a lot more than I thought was loose.
    i'll proably get someone to skim it, dont mind putting up the plasterboard, but how is the tape applied (sorry if it sounds a stupid question)!
    Dean
  5. deanflyer
    deanflyer
    29 Jun 2008
    14
    Thanks Received:
    Tyne and Wear
    Country:
    ok last chance - i've bought the plasterboard!!
    I know to tape the new plasterboard, but do I still tape between the new plasterboard and the existing lath/plaster that there.
    The tape I have bought is like a mesh and is self adhesive, wont this cause a raised edge where the existing plaster is?
    Cheers,
    Dean
  6. Sponsored Links
  7. Richard C
    Richard C
    26 Apr 2005
    10,625
    Thanks Received:
    1,002
    Country:
    A single layer of reinforcing tape between the plasterboards is all you need. I’ve not married lath & plaster to PB before but I would use 3 strips of reinforcing where they join, one either side & another down the centre; I’ve use this method to marry new studwork to existing block work walls successfully many times.
    Ideally you need to skim the whole wall to be sure of an invisible repair but if you just intend to patch repair, it is possible to blend in over the surrounding area; weather or not your chosen plasterer will be able to achieve an invisible repair or not is another matter! ;)
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
