Yes, thanks, see belowAre you doing breaks in the doorways.
Incizo quickstep doortrims are great for that.
Thanks, John. The longest run is 3.5m in all rooms apart from room #3 which is 4.2m. There is a 10mm gap and threshold strip at each doorway.
Thanks, if you see the floor plans there is light from dual aspect sources, windows at 90deg in same room or directly along from the landing.Should be laid inline with main light source .
Thanks, but that means it is mostly like plan A, with just main bed room #3 running the other way, as shown in B.Main bedroom ok in B all the rest should run towards the window.
Ok fine, thanks. But is that just an opinion or are there real practical issues with having them all in line?There is absolutely nothing to gain by having them all run the same way.Only causes problems.
Trying to keep them all in one directions means some rooms could have small unstable sections because they are running the wrong way to suit the room.
Thanks - and more wasteful diagonally I would think, or maybe not?You can always go for the compromise and lay diagonally! A lot more hassle is have thought, but I knew someone did it and loved it. Apparently makes the room seem bigger
Not necessarily much more wasteful, as the angle you cut for one end should match what you need for the other. But it was a tongue in cheek suggestion, I can see it's already a tough decision so I don't want to make it worse! Good luck with it, should be nice regardless.Thanks - and more wasteful diagonally I would think, or maybe not?
amen to that! The aim of the game is supposed to be as helpful as possible, fingers crossed I manage sometimessometimes on forums there are quite unhelpful and blunt retorts almost, can be quite off-putting for the DIY amateur asking what to others might seem no issue.
I just remember reading "everything is obvious to the man who knows", and on this flooring subject, I don't know, but am now wiser, thanks.
