laying laminate
11 Jul 2006
Berwickshire
ive layed a few laminate floors before but my new living room has two large radiators on different walls. ive always started at the radiator previously to make life easier for myself but with two radiators , where do i start?????
I take it the rads are on opposite walls. I would work perpendicular to the rads. When I reached the pipework, I would fit a board in and gently tap it along until I could mark the notch for the pipe. Remove board, cut notch then fix board in position. Repeat for rad at other end of room and then fill in boards between those two. Continue laying boards until next lot of pipework is reached and repeat.
I may not have expressed that very well but I hope you follow the logic.
