Hi
Had a solid wood floor installer advise me to lay 12mm WBP plywood over my concrete floor to block moisture and help to even floor.
Is this the best thickness to use?
Should I lay a DPM under the ply?
He recommended screwing and glueing this - what type of screws and glue should be used?
Some of the floor is floorboards I guess I will only need to screw into this?
Thanks.
Thanks.
