lead gas piping
28 Jun 2005
Wiltshire
Hi can anyone HELP? whist fitting a new kitchen i have drilled through a lead gas pipe hidden in the wall. i think it is an old connection for the original boiler i have traced the pipe under the floorboards in the bedroom but then loose its trace is there a way of capping the lead pipe to get the gas supply back on??????? :oops: [/b]
Turn gas off, break wall to show a foot or so of pipe, call a corgi who knows how to mend a lead gas pipe. Not all will.
I would say that hardley anyone will, blimey its been years since I swept a joint.
Am I right in thinking that lead is now an inappropriate material for gas supply though? It may be worth getting a CORGI to replace the lot asap
Sure is corgiman, under no circumstances must lead be used for gas, however if existing and in good condition the engineer can repair or connect to it using taff joints to the copper.
It depends a bit whether you drilled through the back as well as the front of the pipe!
If it's just the front and the pipe is exposed it's very simple. More of a job if it needs copper putting in. Might be easiest then to use 2 lengths of copper and a slip joint between them.
Of course if it's a disused pipe then it can be capped.
WOOOOOOOO do NOT do that as leadlocks are definatley NOT an appropiate fitting
Got called to house for a gas re-run the whole house was in lead apart from the run to to boiler that someone possibly 5 years previous had tried to solder copper to lead under the floor boards. One mourning the customer got out of bed lit up a cigarette the bedroom window blew out and he spent three months in mount vernon hospital for burns, don't even think of repairing it needs a complete gas re-run in copper
Strange that i wouldn't hesitate to repair it, but then I know how to do it.  8)  8)
being a dinasaur and all that :lol: :lol:
kevplumb said:
ohhh scuse me
how do you catch the mole at your age :wink:
Turn the gas on and wait for it to pop out :lol: trust me he won't stay in there to long :roll: :roll:
kevplumb said:
hence how the bentpin got its name :lol: :lol: :lol:
Oooooh yes you could have some fun with your bent pin, especially in Brighton :oops: :oops: :oops: :oops:
Carryon pic here :lol:
where is flaming willhelm when you want him
GUESS :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Who said anything about using a leadloc?
You can of course solder a piece of copper pipe into a lead pipe and then use normal fittings for gas. You can for example T into a lead pipe. Or cap one off.
Lead pipe installations are often so poor though that I'd prefer to replace the lot. I daresay we've all seen lead water pipes start to weep where they go over something like a damp sleeper wall.
