leakydave said:Never seen owt so weird as your stop tap before.
This is the sort of job that scares me and I am a plumber... it could all go horribly wrong... and leave several flats without water.
I reckon you need the boundary stop tap locating, £ or not, and the lead replacing with blue poly.
Nige F said:And for the Grand Finale ...........It`s a Brighton Pattern stopcock...there is a metal to metal needle valve inside .When closed this allows the main valve to be re washered without further shutting down the water supply. This info may "needle" some, particularly as It was supplied by a Large Rabbit called ahhhh, Harvey
Come on you Cryptographers...are your brains agile enough to decipher this ,or do you need a powerflush
doitall said:Makes sense now we know![]()
In the left hand valve is a seating which when turn off allows you to change the washer in the main body (right hand tap) without the need to isolate the mains externally
jack S the left hand will still be live so water is likely to squirt out unless you can shut it off. You may find if you slacken the gland nut the handle will turn, clockwise to turn off.
doitall said:Question 2.
the left valve turns both side off. the right valve turns just the right side off
