I have an ancient lead tap external to my property. I'm looking to replace this. The stop tap in the house doesn't isolate this as it's on a different feed.
I had the water supplier (Yorkshire) come out a couple of weeks ago to locate the stop tap for this ... which is around 200 metres away on the main road and feeds 6 properties. Looks like when this tap was put in, it was just taken straight from the mains. However, this stop tap needs repaired as it's not working and around 50+ years old.
Anyway - my lead tap is now leaking quite a bit as it looks like the washer inside has gone)
. Is there anything a plumber would be able to do to stop the leak /replace it (freezing?) before the two week wait for the stop tap to be fixed?
