Leak coming from toilet pan nuts
9 Jun 2014
Yorkshire
I have a leak on a toilet. It is dripping from the nuts which hold the pan and the cistern together.
I haven’t been out to look yet but wondered if something might have broken in terms of the ceramic.
Will the fix be to just tighten the nuts ?
No this is not when flushed as I know if that is the issue its the donut washer.
This is leaking constantly, a small drip, but it accumulated a pool under the toilet over night. I have seen a vid showing a drip running off one of the connecting bolts.
Must be leaking between the flush valve and cistern as well as the donut. Remove the flush valve, reseal and refit. Fit a new donut washer as well.
It may have nuts and bolts that run all the way through from inside the cistern, with butterfly nuts and washer fitted below that pull the cistern down onto the pan, if so then those seals could be leaking.
Look inside the cistern, can you see bolt heads and rubber washer on the bottom of the cistern?
I am there tomorrow morning, but I think it does have the bolts going all the way through and has those big plug washers in the cistern.
My old toilet cistern used to get covered in condensation and run down and drip off one of the bolts underneath.
