- Joined
- 6 Nov 2003
- Messages
- 327
- Reaction score
- 4
- Country
I took my toilet out to tile under it. Got it all back in and screwed down OK but as I knew I have a gap between the Cistern inlet ant the water feed. The feed is really fillered in and so I didn't want to have to move it.
So I went and got a male to female coupler thingy. Put it all together but I've got a leak I can't get rid of!
Sorry second pic a bit dark.
I'm pretty sure its coming from the top of my coupler, i.e. the join between the cistern and my coupler.
I've got an O ring in there which I'm not sure I should have?? I didn't have any PTFE but I didn't think I would need it??
Should I be just screwing the cistern threaded pipe into the coupler with PTFE or is there a completely different way to do things??
The leak is very small but I'm scared of tightening the coupler too much onto the plastic cistern feed, I'm pretty sure its as tight as it can be.
The only other thing I can think off is to get a small flexible pipe that are around these days and use that between the feed tap and the cistern?
Any help much appreciated!
Paul.[/img]
Paul.[/img]
