Leaking backdoor
5 Feb 2007
Liverpool
I have a UPVC backdoor when closed and handle is pulled up has a gap on hinge side about a foot up and about a foot on bottom. I have adjusted the hinge in with screw on hinge but it is not pulling the door in. Anything I should be doing or checking ?
Found the problem. I basically need to adjust the bottom hinge in abit but the screw that adjusts is knackered. Its a pendulum hinge which is 100mm but I forgot to measure the rebate at the property. I have looked on Ebay for hinges and there is 11mm and 13mm rebate do I need the exact one or could any of these do ?
