Leaking bath waste pipe
22 Jul 2005
Lancashire
I've recently had a new bathroom suite fitted, and I've discovered a small leak between the flexible plastic waste pipe and the right-angled pipe joining the bath.
As you can probably tell from the above description, I have little-to-no idea when it comes to plumbing. But, as I'm reluctant to get the fella who fitted it back (for a number of reasons), I wondered if anyone could tell me what the most likely cause of the leak is, and in easy step by step instructions, guide me to fixing it if it's simple.
Thanks.
Not the best of descriptions but it sounds like the overflow pipe. If it is kind of wrinkled and black then I'm on the right track. Generally they are nasty cheap affairs but you could probably do worse than easing it of the connection and putting plenty of silicone sealant around it before putting back and leaving for 24 hours. Ensure its dry and clean first and use sealant meant for sanitory fittings.
on top of basses description does the pipe go verticly up [just wondering if it could be a normal junction]
another thing to consider is get the person who fitted it back in to repair his or her work
Sorry for the poor description,
Its definitely not the overflow, its the main waste - which goes from the plug, down into a small U-bend - then joins the flexible pipe to the outside wall.
Its at this joint where the leak occurs.
Am I right to believe that there is a metal ring inside which presses up against the rubber washer to seal the joint? Could one of these components be missing?
Using a sealant is an option - but is it not better to fix the cause?
Its a plastic ring normally just doitup a tad, (the nut that is) :lol:
