- Joined
- 15 Jan 2020
- Messages
- 13
- Reaction score
- 0
- Country
Heya guys, I'm trying to find info + solutions but being new to owning a house I am struggling getting the right info etc, maybe I'm searching for the wrong terms - hopefully you guys can point me in the right direction.
I have recently purchased a ~1900s Victorian mid-terrace, the bay windows at the front go from floor to roof (2 floors) with brickwork gap between the floors.
Everything (seemed) to be fine until this very recent bout of endless rain, and I turn up at home last night with water dripping from the wood above the window in the downstairs bay.
I have done some checking and don't see any big obvious holes, but I've noticed the grouting seems "new" and the white "rendering" (sorry if they're the wrong terms) on some parts is cracked and also has a big gap between it and the brickwork.
A friend also pointed out that some expanding foam seems to have been used.
So obviously I would like to help try to prevent the leaking, so I can only think that:
1) I may need to remove the grouting and redo it maybe with different grouting (I've heard that some houses may have used lime-based grouting to allow 'breathing'?)
2) I will need to remove the foam filler and refill with - presumably - grouting
3) I should remove the "rendering" with a heat-gun + scraper and re-apply a base coat and render
4) I will have to wait until the rain stops to give it a few days to dry out
.. is that about right?
Anything anyone can help with for advice on types of things to use, terminology, how to apply them, etc?
Should I get a "pro" in?
Anything I can do to help prevent the current water damage which I fear might be also affecting the ceiling?
I am attaching photos to help my description above.
Any help would be massively appreciated!
Whizz
Whizz
