R
ringy1
I serviced a firebird super Q the other day upon servicing when i was doing my FGA and when i was adjusting my pump pressure oil started to leak out through the slot where you adjust the the pump pressure, so i told the householder pump needed replacing other wise the burner could not be set up properly. Has anyone came across this problem before and is there away of sorting the leak on the pump or is it just a case of replacing pump if this happens cause its a bit of a ****** servicing a boiler and then having to replace a pump that was working fine until you adjusted it, It does not make ya look good. Bear in mind this boiler is about 15 years old and was never serviced before
