Leaking shower tray
20 Jul 2008
Warwickshire
I recently fitted a shower cubicle and tray in the corner of the ensuite. I fitted the tray tightly to the wall on its frame and tiled down on top of the edge of the tray. I grouted the 1mm gap between the tiles and tray aand then smoothed a good quality silicone sealant over the top so I thought it would give two layers that are waterproof. Unfortunately, I can see a small leak (few drops) dripping down behind the side of the tray onto the floor. Fortunately, it isnt enough to drip onto the ceiling below but I realise that I must sort it out somehow. The rest of the tiles on both sides are secure and I have grouted neatly.
How can i get rid of the leak ? Is it a case of a thicker bead of silicone around the tile/tray border ?
Thanks in advance.
You need to be filling the joint with silicone rather than grout. Remove the silicone and scrape the grout out. Then re-apply the silicone again.
Sorry but I have tried removing the grout and have applied a good thick bead of silicone sealant. I left the shower for three days before using it and I am afraid that I am still getting the same leaks in the same places.
Do you think I should use epoxy grout ?
Thanks in advance
