Hello all,
I'm looking for some advice or recommendations to fix a leak that has developed on an external soil pipe. Attached is a sketch of the problem area. Basically the leak is on a push fit plastic elbow. For some reason the rubber joint pushed itself out - I dont know how or why but it has. The problem is that the elbow is partially buried in the houses external wall so its not easy just to replace with new, at least with out having to bash out the render and mortar thats keeping it in place. The pipe is also fixed at ground level.
I have tried a sealant but it wasnt up to the job as it leaked again after a few days.
If someone can recommend a good sealant or other way to fix the problem it would be greatly appreciated.
