leaking water butt tap solution
27 Aug 2019
hi all , can anyone please recommend something i a can use to stop a water butt tape leak please? also while i am here i also have a problem with fitting that goes onto the tap which is on the end of my hose, that leaks as well any help greatly appreciated thankyou :-)
thankyou i seem to often be buying butt taps , if i accidentally move the part of the tap that goes into the butt it starts leaking so was trying to find a alternative to the problem, not sure if washer would work on fitting on hose because my ones seem to leak out of the middle of connector and i dont think the connector comes apart. but thankyou maybe i should resign myself to constantly replacing. annoying though.
Worth a couple of pictures to see the type of connector.
Is your tap screwed into a thread on the butt or through a hole with a backnut?
tap is through a hole with a plastic nut it may have come lose, will have to get someone to check as i am only 5ft tall. the connectors on image insert can move up and down. dont know why i always have problems with my 2 water butts. wondered weather i could use tape or a sealant? keep replacing them but within weeks have same probs
IMG_20190828_150953.jpg IMG_20190828_150953.jpg IMG_20190828_150953.jpg IMG_20190828_150953.jpg IMG_20190828_150953.jpg
The O rings on those connectors perish. You can buy replacement O rings made for the job on ebay.
There should be a soft rubber seal between the flange of the tap and the hole it fits into in the butt - Outside the butt, rather than inside. You can tighten the plastic nut by first emptying the butt, laying it on the ground, then reaching inside with a pair of adjustable water pump pliers - you may need someone to hold the tap still, whilst you tighten the nut inside.
great idea to get quality connectors will save me money and stress no more cheapys for me thankyou
