Hello
Our 3 year old bath mixer has gone all leaky. It's leaking from the slide / pull mech for the tap & shower diverter.
I've taken it all apart and it appears to be missing something (which I assume has simply eroded).
Lets start with a picture of a similar tap set
The main spout body has a slide to switch the shower or tap flow.
The slide when disassembled is a brass shaft with a sealing washer and conical valve at the base ( to seal the water flow between shower or tap spout).
Above this is a spring that sits over the brass shaft, then there's a small metal washer and then the handle for the lever screws in the shaft at the top.
So what appears to be knackered is the absence of any form of seal between the washer and the lever. This allows the water to run out of the lever pull part of the tap body.
If anyone understands me, well done !!
And if so, what is used as a seal and where might I get one?
At the moment I have used some s/a tape wrapped round the pull shaft to create a seal. This means the bath can be filled, but there's no way I could seal it and then offer the Mrs the luxury off the pull working
