Help, my bath overflow is constantly leaking a stream of water.
I think the water could be a over flow from the toilet.
How can I stop this water leaking in the bath???
Many thanks
If you live in a flat and there was no outside wall available, the overflow from your toilet may have been fed to the bath overflow.
Lift the lid off the cistern and check to see if its overflowing. If it is, then you need to change the washer in your ball valve or if its totally had it, the whole ball valve.
