Hi all,
Frustratingly this is something I've done on other toilets, but either too many blows to the head, of the mysteries of time have stumped me on this one.
I've bought a Fluidmaster Bottom-Entry Lever & Fill Valve Cistern Pack to replace an aging float valve system that was making a lot of noise, all seemed to go well (despite having rusted screws and bolts to extract), but now it leaks - and it leaks to such a degree that I've clearly done something wrong.
Basically, the inlet pipe leaks where it meets the bottom entry - the fiber washer is there, and didn't previously leak, so would think it shouldn't be that - and also the backnut leaks water, so it's not holding it either (rubber seal is in on the inside, etc) - I don't know, does this suggest that things are not lined up properly?
There was a lot of plumbers putty in the tank, and I've removed most of this so it shouldn't be affecting the seal, and we now live in a high water pressure area
I'm probably going to realise I've done something stupid soon, but until then... any ideas as to where I've clearly gone wrong??
