    Dismiss Notice
Lean to Timber Rafter Size
Discussion in 'Building' started by 1975bloom, 6 Sep 2017.
  1. 1975bloom
    1975bloom
    6 Sep 2017
    37
    Thanks Received:
    2
    Country:
    Hi, first question, I have a Lean-To Conservatory W 5.3m x Projection 4.5m that I want to change the roof to a light weight tile roof. The conservatory has 6 x 2 timber rafter space at 700mm. A builder told me to put new 8x2 rafter in space at 400c but can I just add extra 6x2 rafter so spacing will be 350mm or double up the rafter, as this is going to be light weight tiles. Many thanks
  2. Sponsored Links
  3. chappers
    chappers
    27 Aug 2004
    3,254
    Thanks Received:
    357
    Country:
    Not really, what is the pitch of the roof, even 8x2s are really underspeced for 4.5m span even at a 30-45 degree pitch.
    More importantly you say it's a conservatory, is the actual structure capable of taking the extra weight of the rafters and roof
    • Thanks Thanks x 1
  4. 1975bloom
    1975bloom
    6 Sep 2017
    37
    Thanks Received:
    2
    Country:
    Hi, thanks for replying, its hardwood timber frame with dwarf wall on 2 side and a full high wall with double glaze window and door, I think the pitch is 10 degree. I have 6x2 rafter and had no problem, the conservatory is 15 years old.
  5. chappers
    chappers
    27 Aug 2004
    3,254
    Thanks Received:
    357
    Country:
    trada tables say that 8x2 is just about OK. whats the roof currently made out of?
    Your other issue is that 10 degrees is into flat roof territory. There aren't many slates or tiles that work at such low pitches.
  6. 1975bloom
    1975bloom
    6 Sep 2017
    37
    Thanks Received:
    2
    Country:
    Hi, Its c24 6x2 timber painted with polycarbonate sheets, I want to put lightweight conservatory roof tiles on.
  7. chappers
    chappers
    27 Aug 2004
    3,254
    Thanks Received:
    357
    Country:
    seems there are some products that will probably work for you superlite being one and some of their range works down to 10 degrees. sounds like doubling up your rafters may work.
  8. 1975bloom
    1975bloom
    6 Sep 2017
    37
    Thanks Received:
    2
    Country:
    I hope so, Thank you for your help, .
  9. DIYnot Local
    3 Sep 2019
    Country:
  10. Sponsored Links
Loading...
Share This Page
