LeanTo roof - approximately 3 meters out from house with 570cm spaces between rafters (will add noggins too).
Buying plywood from Wickes. Options are:
9mm thick, non load bearing (internal or external if treated).
12mm thick, non load bearing (internal or external if treated).
12mm thick, structural load bearing internal or external.
Not sure which one to go for. I'm thinking 12mm is overkill and might add too much stress on the framework?
I will be walking over it but only for house paint touch ups. I weigh 58kgs. I don't think that justifies needing structural plywood.
It will be covered by thick felt (not the shed type but the thicker version that's usually torched/glued on).
Thanks.
Thanks.
