Hi all , wondering if you can help.
when I fitted a Legrand dimmer switch to my 2 way circuit the lights were dimming and then brightening constantly on there own? At first I thought that maybe a duff switch so I replaced it but still does same thing. The switch it the main switch on the 2 way, ie it has the live in and switched live out from and to the rose plus the three core to switch 2. I expected it to be just a straight swap but that did not work. The bulbs are not Energy saving or Gu's, just 5 normal 25w candle bulbs in two fittings so 10 in total making max wattage 250w and switch is rated to 300w??????
Any clues on the problem peeps
thanks
thanks
