LG Washer / dryer F1403RD , dryer not heating up
13 Apr 2017
First of all welcome to all ,
I have a F1403RD LG washer dryer but the dryer has suddenly stopped heating up. At first I would get error DHE roughly on 19 minutes into a 30 minute dry. After the error I replaced the dryer element and the Thermister dryer sensor the 2 prong job with parts from 4lg. I didn't replace the Thermostat in the metal dryer duct so could it possible be this? also, how do I test this ?.
It still doesn't heat up on dry but the DHE error doesn't appear and now it goes to the end of the cycle as normal but cold. I also took the plastic vent dryer duct off the back of the tub and cleaned it out but there wasn't much in it as I had cleaned this about a year back.
I'm now at a loss as to what the problem can be. How do I now check to find out what's causing the error ? any fuses or blocked pipes I should look for ?
Any help would be greatly appreciated.
thanks
To test the thermostat you just need a multi meter set to resistance & check for continuity. If you are competent to do so you can also check if you are getting 240v at the element & other components with it.
Thanks for that, so this morning I checked the element to see if it were getting power which it was and I tested the dryer thermostat to see if it has continuity and it checked out fine.
It was then I watched a youtube video:-
I banged it on the tiled floor a few times and put it back in and unbelievably it started back up !.
I will have to order a new one just to make sure but it seems I found the problem. What threw me was the continuity saying is was OK.
thanks for the advice , much appreciated
Well done but it cannot have had continuity as they go open circuit after overheating & banging then resets them & gives you continuity. :)
I thought that but I checked it before hand and it did then after I banged it it worked, whatever the banging did made it work , continuity or no continuity my clothes are now drying :)
