Hello,
I've just moved into a new property and I'm trying to put up some light fittings. I've done it before but I seem to be running into problems in my new house.
Basically previous there was a ceiling rose and I'm trying to fit a new light that has 3 connection blocks (live, neutral, earth). I've removed the ceiling rose and connected the 3 live connectors together. However, I literally can't fit the remaining 6 cables into the chocbox that comes with the light. The cables coming down from the ceiling are really thick solid core wires. I've already accidentally snapped one trying to bend it.
I need to connect 3 earth, 2 neutral and live from switch into the 3 connectors inside the chocbox but there is physically no way they'll fit into the box or fit inside the tiny screw connectors inside. Plus even if I could get them to fit there is no way I can fit all that into the fitting, there isn't room.
I was thinking of going into the loft, pulling the wires back through, joining them together in a bigger junction box in the loft and dropping just 3 wires down through the ceiling.
Would this work or am I missing some simpler way of fitting the light?
Thanks,
Tom
Thanks,
Tom
