got a fan light, when i switch it on the bulb constantly flashes, as if its going to explode, i have changed bulbs and it still does it.
what could be the problem?
If you bought it new from a shop, take it back and complain.
Otherwise, you, or someone, will have to cut the power to the lighting circuit at the consumer unit, take it down, open it up on the kitchen table and check for loose connections or damaged wires.
