light on a tester screwdriver from light earth wire on a light switch, that in turn is give a light on the back box and screws.
I have looked at all the switches and light fittings that are in the circuit no loose connections with wires, nothing perished, also not sure of how much power is going to the earth or even if this is normal spike? For limited saftey i have tapped up all the exposed screws on the covers and only put the lights on in that loop when needed.
I now have a multi meter but have no idea how to use it? Can i put it to volts wavy line ac 200 and then put the red prong to the suspect earth wire then the black prong to what? To get a proper reading?
I recently swapped a light switch out that i thought might be faulty as i had a none working light, i swapped everything like for like, and the light is working, i only noticed the feedback from the screws because i used a tester screwdriver to put the cover back on, could this have been like this for a long time? Could i have wired this up in such a way that it would cause this? Nothing visable is touching any of the back boxes and earth wires in the loop? And nothing else has been done in the house, could it be something done in a next door house?
An electrician will be called to fault find and give it a health check? But until i can get one to come out i would like to do some diagnostics and try and make it safe or discover that the feedback or charge going to the wire is not lethal or could cause any damage.
Thanks for any advice in advance, please make any explanations simple and in laymans, i have watched a ton of youtube and read lots on this, and they all seem to go off on a tangent.
