Light Question
18 Oct 2009
Hampshire
Hello
So I currently have 6 X Aurora AU-FRLD811/40 m10 LED in my lounge.
I want to replace them with 6 X GU10 downlights.
As I want to be able to install Philips Hue bulbs into them.
Would the quick connectors work with a GU10 bulb?
Cheers
Paul S
The quick connectors are 230V. Philips Hue GU10 lamps are 230v devices.
I guess you are replacing the M10s with a completely different 230v downlight?
If so, the answer is yes. I would buy
some more quick connectors and leave the existing half on the existing wiring.
you then have 6 x M10s with connectors that you could sell on FleaBay, etc.
Thanks, good advice yes I want to sell the old ones as they are far too bright and the dimmer switch makes a buzzing sound.
I have been told with Hue lightning you can dim them and you can turn off individual lights.
