I'm sure people would John, but I don't see how that makes it a poor analogy!
Yours would have been a good analogy if people were advocating 'jamming a stick' into electrical outlets to protect them - which I haven't noticed happening.I'm sure people would John, but I don't see how that makes it a poor analogy!
Fair enough - but my point remains. In terms of the language you're using, I think the only reason why they are not jamming commercially-produced sticks into gas outlets is because they can't find any such commercially-produced sticks to buy - rather than, as you suggested, because they would laugh at the suggestion that they should do it!They would still be 'jamming a stick' into the outlet, it's just a commercially-produced 'stick'!
IMO it looks a lot better painted, you'd be better changing the socket to an MK brand and throwing the protector things in the bin.
No, we're saying that you don't need the socket protectors whatever make of sockets you have. All 13A sockets are made and tested to a British Standard (BS1363) have integral shutters that prevent access to live parts. You should not interfere with those shutters by using socket protectors, which are not made to any standard and can cause damage to the sockets.IMO it looks a lot better painted, you'd be better changing the socket to an MK brand and throwing the protector things in the bin.
Major thread hijack, but are you saying if you use MK sockets you don't need the protectors?
Because I use white MK sockets exclusively (and the socket protectors for my 2 year old)...
Because some companies make money out of them, and some people are sufficiently gullible to buy them.Without stating the obvious, why are they sold here then?
Because people have been led to believe the myth that they are necessary, and by pandering to that myth manufacturers and suppliers can make a little extra profit.Without stating the obvious, why are they sold here then?
Indeed - but, to be fair to those who buy them, those organisations which have advocated (or even 'required') them, and maybe even some of the companies which manufacture them, they do, at first sight, "sound like a good idea" - so maybe 'gullible' is a little harsh. "Lacking in technical knowledge" might be fairer.Because some companies make money out of them, and some people are sufficiently gullible to buy them.Without stating the obvious, why are they sold here then?
As others have said, you absolutely do NOT need those protectors with any standards compliant socket.Major thread hijack, but are you saying if you use MK sockets you don't need the protectors?
I don't think that's a theoretical risk, Fatally Flawed does a pretty good job of demonstrating actual risk - damage to sockets (higher risk of overheating/fire, higher risk of ineffective earth connections) and making live contacts more accessible.... and have the theoretical capacity to 'do more harm than good').
We've been over this ground many times before. In the absence of statistics, at the level of the 'bottom-line' (actual harm to human beings), we can only really talk about theoretical relative risks. Fatally Flawed can, indeed, demonstrate damage to sockets resulting from use of these products. I think they can even provide (or at least link to) videos of small children 'almost doing very dangerous things' as a result of their use (but not actually coming to harm - at least, not in the videos!). However, I don't think even they can produced even one well-documented case of anyone (child or adult) having been harmed as a direct result of use of these things.I don't think that's a theoretical risk, Fatally Flawed does a pretty good job of demonstrating actual risk - damage to sockets (higher risk of overheating/ fire, higher risk of ineffective earth connections) and making live contacts more accessible.... and have the theoretical capacity to 'do more harm than good').
A very valid point - but one which also applies to safety measures which work (up to a point) as well as those which don't - seat belts, ABS and RCDs being the first three examples which come to mind. However, as you say, all considerations which need to go into the relative-risk melting pot.I'd suggest the main area where the risk is up for discussion is whether they provide a false sense of security. Do people pop these in, and then not worry about little Johnny poking things into sockets ?
'Higher risk', yes, but that is a theoretical concept, and still does not necessarily prove that anyone has ever been harmed as a result - or, more crucially, how this theoretical higher risk compares with whatever risk, if any, is associated with not using these products.As Fatally Flawed demonstrate, and has been pointed out here, it is actually quite hard to poke some random object into a live contact - but with some of the "safety" covers, it actually is easier. So combination of parents less concerned, and dangerous activity being easier = higher risk.
