Hi guys (and gals)
I've been looking through the site, but can't see a solution...maybe I'm not understanding what I'm seeing...anyway..
Just replacing a light switch in the house, single ceiling rose light, single switch.
Copied the wiring from original switch, then tested the switch worked okay, so I pushed the switch back into the housing then FLASH-BANG !
Turns out the earth bar that the switch plate screws onto has a badly positioned earth poiont, in the middle.
Making it stop the switch going into place properly.
So, I moved the earth point along the bar, wired it all back up and nothing...still dark
Started searching this forum for help, still no bright ideas...so thought I'd register and ask.... stopped for dinner and tried again before posting this !
FOUND the problem.....on of the wires that went bang actually blew apart, but still left the outer insulation in place, so it did'nt look broken.
removed the broken bit, rewired and ....
Thought I would post this in case it helps anyone else.
Always check wires are continous after a flashbang !
Thanks all !
Thanks all !
