can anyone help, mcb keeps tripping on lighting circuit been working fine and nothings been touched or altered, changed mcb and it is still happening, theres only 3 lights on the circuit
the mcb started staying on for 20 min and about 5 min there after. It as only just started and the circuit as been there some time. The light fittings have not been changed. Lights are failing on the ground floor. There is a kitchen in the floor above and not seen any mice
you probably have damage to a cable or fitting. If it is a fitting you may be able to find signs of overheating. Could be a wire come loose in ceiling or switch.
mice gnaw cables and damage them, hence my question.
cables are often damaged by nails or drills into walls, less often into floors or ceilings. Cables generally work perfectly unless they have been damaged.
Water leaks can get into ceiling fittings especially if under a bathroom.
If you disconnect any wires in a ceiling fitting ir is essential to draw a diagram and mark every individual wire - doing it by colour is not enough.
I presume you do not have any non-lighting loads connected to the lighting circuit, and no huge lamps including horticultural growing lamps, or heater lamps for tropical fish or reptiles.
