Am redecorating our conservatory. Sockets are on a 2.5mm ring. Have a light switch, FCU and double socket next to each other.
It appears that the lighting circuit is not connected to FCU for when I remove fuse the lights remain on. I can sort this once I get around to removing some units.
Question: should the cabling from FCU to lights be 2.5mm (as they are now) or be reduced to 1mm / 1.5mm?
Secondly, if I need to - to avoid recabling or extending the circuit with more cable - is permissible / bad practice to crimp terminals within the back box of a switch? the neutrals as in diagram below:
View media item 26233 [/img]
Thanks in advance.
Thanks in advance.
