J
johnmf
in an industrial unit ive just rented theres 6 400watt high bay lights all fed from a 1.5mm 2 core armoured cable. i work the load out to be 10.5 amps. the protection is a 16 amp mcb type c. havent got a copy of the regs to check this out so am not sure what 1.5mm 2 core swa is rated at but i think its borderline! is this set up ok? the cable is just about impossible to change n i cant cut down on the lights but the next mcb down i believe to be 10 amp. any suggestions?
