hi guys i hope you will be able to help with a couple of questions i have.
i have 3 light switches in my front room, 1 switch runs 1 ceiling rose and 2 switches run another ceiling rose. originally 1 switch run 1 light up one end of the room and another switch run the other light.
the light that is run by 1 switch is being removed (switch and light) when i have located the wires, for switch and rose, is it safe to chop the wires under the floorboards upstairs and use a terminal block to render them safe ? or do i need to trace them back to the junction box ?
the previous owner moved a doorway and installed a new switch to the new door location keeping the original switch where it was (floating in the middle of a wall now !) i now would like to remove the original (floating) switch and run the light of the 1 switch which is at that end of the room. the original switch has 2 sets of wires going to it and the new switch has 1 set. which is the best way of doing this ?
and lastly when i have completed those tasks i would like to then add 3 downlighters which i would like to run from a new switch. is it a case of running a feed over to the new switch and then onto the downlighters daisy chain sytle and if so where is the best location to get a feed from ?
i hope that makes sense and you guys will be able to help. id love to be able to pay for a sparky to come in and do it but money tight at the moment and i love to learn new things ! thanks for your time and expertise
