Lighting the pilot on a c95ff ideal combi boiler
3 Jan 2009
I apologise in advance if this sounds like a daft question but my... ahem... wonderful C95ff's pilot has gone out and, unlike other boilers that have sensible igntions, i have absolutely no idea how to fire it up again (and no manual with which to do so - i'm afraid that it came with the house). any suggestions?
cheers
This is the higher power version of the C80FF boiler, actually quite rare! But no special value as its only a boiler.
But it does not have a pilot light!
It lights the gas when it needs to.
It sounds as if you will need to call a competent boiler engineer. Make sure he is familiar with that boiler as its not that common.
No pilot on this one son - could be a flow switch issue, but any decent engineer will be able to check pump proving switch is making.....
If not that then APS can be faulty, and even O/H stat as that cuts power to G/V on these...
