My daughter has just moved house, and asked me to fit a couple of dimmer switches for her.
Simple job I thought, and to be fair it was, but I was most surprised by the wiring method.
When I took off the switch, there were 3 T&E cables in the box. One was L&N in, one was L&N out, and the 3rd one was to the light. there was a connector block in the wall box where the 3 Neutrals were connected together, and the same for the earths.
I'm used to seeing the all the connections being done at the ceiling rose, with only one cable going to the switch.
Is this some new wiring method, and why?
Seems a bit daft to me as there are perfectly good connectors in the ceiling rose so why use a block in the switch box?
Must use a fair bit more cable as well, I would have thought.
House is 2 years old, BTW
What do you think??
What do you think??
