Lining a Cupboard
20 Dec 2006
Stirlingshire
I'm just about to get my central heating system replaced, which will free up a cupboard in the kitchen as the hot water tanks will be removed. At the moment, the cupboard is not lined in any way, and the back of it is just the stone from the exterior wall (Victorian sandstone house), with a little bit of plaster left on (I assume it wasn't always used like this).
The floor is a raised wooden one so that bit is ok.
I'd like to turn it into a useable cupboard, but don't know how best to go about converting it.
My thoughts would be:
1. Build wooden frame (should the wood be treated first?)
2. Attach plasterboard to frame (which type? I know you can get foil backed etc)
3. Paint or lining paper it.
4. Done
Is that correct or should I approach this from a different angle?
you've pretty much got it covered, though i would add some insulation and vapour barrier into the mix. :wink:
Thanks Noseall, how much of a gap should I leave between the wall and the frame/plasterboard?
Should I treat the wood with anything and should I get the foilbacked plasterboard?
You might also want to tape any joints in the plasterboard just to finish the job off ready for painting,even though it's only a cupboard.
Roughcaster.
