Hello All,
Was hoping someone might be able to point me in the right direction to save me pulling out what hair I have left!!
I have lined my walls with 1700 grade lining paper (Wish I had them skimmed now!) and being a novice at paper hanging, took some advice to leave a small gap of 1-2mm between joins and then fill them afterwards to leave a seamless finish after painting.
I have tried filling with layers of paint...which hasn't worked! Tried using Polycell premixed fine surface filler, which sets rock hard so cant sand properly without ruining the paper and leaving an obvious "fill line", and normal GP filler (mix your own), which has probably had the best results....but you can still see a slight gap
Can anyone tell me what I'm doing wrong...surely it shouldn't be this tricky??? Is there a technique to use when filling, or am I using the wrong products??
Thanks in advance
Dan
Thanks in advance
Dan
