- Joined
- 16 Jul 2006
- Messages
- 60
- Reaction score
- 1
- Country
The three under-cabinet lights in the kitchen of my daughter's 2001-built flat are not working. They are each about 35cm x 6.5cm and have a single small clear bulb behind round frosted glass. On the back is a label which says IP20 Linkable Cabinet Light 1x20watt. It looks like the sort hanging up in Homebase. Each is fed from a female lead which in each case comes from a small round junction box next to each light. Wiring from junction boxes goes behind wall tiles. Each unit has integral switch as well.
I've identified the wall switch (one of a four-gang) which controls the lights and the red and black connections there appear secure. By poking a circuit tester into the feed leads of each light, there is a current showing on one side (normal I expect). She has replaced bulbs. The last of the light units furthest from wall switch seems to have a very slight scorching from the gubbins inside. I can't get light from any of them in any permutation.
Any ideas? All help appreciated as always. Thanks.
