Linking into a neutralizer
12 Nov 2009
Derbyshire
Can anyone help me with the following query?
I have an oil fired Rayburn 480k which runs on a pressurised system. I would like to install a solid fuel stove and link the two together through a neutralizer. Is this possible as the Rayburn is a pressurised system and the stove would be gravity fed?
If this isn’t possible is there another solution?
Thanks in advance.
Simon
nope, dunsley requires both heat sources to be open vented.
alternatives solution would be thermal store,Have a look at advance appliances or bettre still DPS.
Thanks lcgs.
I presume I would be able to convert my fully pumped system to open vented if necessary?
Thanks lcgs.
Yes this is perfectly possible and acceptable! I'd also give a vote for the dunlsey solution. Its not a cheap box but does work!
