A couple of weeks ago, I noticed some cracking in the outside brick wall of my house.
This took the form of diagonal cracks through the mortar only above the lounge window and another vertical crack below the window.
I phoned the insurance company who have then assigned a structural surveyor to come out and have a look at the house.
I'm a little confused by his report. Can you help?
Description of Damage.
The claim relates to the following.
Externally there is a 1mm vertical crack in the front elevation below the front window.
Externally above the windows to the front and rear there are tapering cracks being approx 2mm in width.
Internally there is a 1mm vertical crack in the plasterboards to the front elevation.
Cause
The pattern of cracking in not indicative of subsidence. It is concluded that the damage is due to thermal movement and wear and tear.
Measures
We would recommend that the lintels are inspected and repaired as necessary. The cracks should be filled and repaired as a matter of routine maintenance.
The house was built in 1985, it's a red brick house typical of that time. I've not heard of a lintel inspection before, how would this be achieved? What's involved?
Cause
Measures
