Hi guys, looking for some help on this.
Heres an idea of setup.
The shower supply is separate from the old CU as there are two sets of tails coming from the key meter. 1 set going to the old CU and 1 set going to the double pole 40a RCD shown below.
This is the sequence from the key meter.
Keymeter - tails - double pole 40a RCD - tails - connector block inside CU taped up - 6mm T&E - 45a Pull cord - 6mm T&E - Shower connection.
The live and neutral have melted inside the shower casing. This is only only the shower side of things. this in turn has melted part of the shower casing.
The RCD has never tripped and the only reason this was even noticed at all was due to the smell of burning.
I am going to replace the shower. I need to know if the correct thing to do is......
keymeter - tails - double pole 40a RCD - 10mm T&E - 45a pullcord - 10mmT&E - 8.5kw shower.
Any help on this would be great. And also any idea as to why the shower continued to operate without tripping.
Thanks.
Thanks.
