- Joined
- 27 Oct 2013
- Messages
- 218
- Reaction score
- 10
- Country
Hi everyone,
First post so please be kind
Ok, here goes...
The plan - recently purchased dormer bungalow. Idea is to remove part of the existing wall between kitchen and dining room (will be leaving 650mm each side). Span is approx 1800mm. BC has been notified as this is part of an overall plan of works. Steel beam will be going in 178 x 102 19Kg as per BC stated requirement 2.1m in length.
The issue - looking above, where the new beam has been added to support the joists for the pre-existing dormer floor the beam is sat only half onto a block which is itself directly onto the load bearing wall to be partially removed. Also if you look at the 3 vertical blocks that are supporting the purlin the very bottom one is badly crumbled and had a crack all the way vertically down its centre.
The load bearing wall is single skin, sat on 2 course of normal house brick on concrete raft at the base and block solids all the way to top with beams sat directly on top.
My origional plan was 3 x props eitherside, remove 1 course under the beams (leaving 1 course to rest direct on the the new steel ie steel/ 220mm block course/ceiling beam).
My question is - Im not happy about the state of the blocks supporting the purlin or the dormer beam. Any advice other than just replace like for like ? On the 3D plan this is the green block marked.
Also worth noting the blue purlin on the 3D plan will be removed on the section on the very right of the drawing when a new dormer goes in.
Pics below hopefully help
Ok, here goes...
