Wiring up converted loft, No access from above the ceiling as its a flat roof above. I thought best approach was to run separate cables to each downlight from a main junction box point to avoid having junction boxes in the ceiling which would be a pig to get to and work on. The rooms being wired have large floor to ceiling cupboards which I thought might be a good place to locate the junction boxes but I am not sure the best way to go with this, as I see it there are two options:-
(a) Mount JB's AND cables on surface of cupboard interior walls in mini-trucking. I think this allows me to run the cables where I like? and also locate the junction boxes where I like? Is this correct?
(b) Run the cables within the cupboard stud-wall AND fit the JB's inside the stud wall as well. I then provide access with a standard drywall access panel. I prefer this approach as the JB's are not exposed to damage. However, I guess this is going to make the wiring routes fare more difficult as they will need to run in permitted zones. Can I apply the standard zone reguations inside a cupboard? For example, can I run cables up/down the corner areas (125mm from actual corner).
My gut feeling is option 'a' is going to be the most pain free?
