Lockshield valve spindle won't turn
20 Jan 2012
West Lothian
Hi
I closed a lockshield valve (and disconnected it) so that I could replace a radiator. I reconnected the lockshield to the new radiator and then found that the spindle would move only a fraction of a turn and then stop. Even some gentle force will not turn the spindle.
Does anyone know what has happened?
Will I have to drain down the system and replace the lockshield valve?
All replies appreciated. Help!
It's jammed - either the thread on the valve or the jumper with the rubber seal - it may go with a bit more persuasion and then it'll click and unwind, give it a spray with some penetrating fluid first.
Thank you, Madrab, for the quick reply. I did exactly what you advised. I ran penetrating fluid down the spindle overnight. This morning, I used a litlle bit of extra force and the spindle 'jumped free', as if it had forced it's way past a bit of rubber washer. Thank you again.
Is it a sealed system?
Thanks for the reply. It's a combi system. If it had been necessary, I would have taken pressure out of the system by opening the drain cock. I assume that I would have had to drain the whole system to change the lockshield, as the new radiator is in the kitchen.
