Hi again sparky persons, more E-advice required please.
I'm installing a neon light (about 1 meter long) in to a small loft storage space behind a bedroom wall. I'm planning to source the power from the back of a socket in a bedroom which is on a ring main and easy to get at because it's in a stud partition. I know this will need to be run via a fused connection unit. There will only be one neon on the circuit and nothing else at all so i'm planning to use a 3amp fuse.
Some questions for you all.
Is this the right fuse rating, it seems to be the smallest fuse I can get.
So that the fused unit is easily accessible I need to run a length of cable to it from the back of the socket for about 4 meters, clipped to a joist. Is this acceptable. I could put the unit by the socket but this would involve a dusty crawl in the dark to change a fuse. I could put it in the bedroom but it would be long way from the light and far from obvious where the fuse for the light was if it blew. I would know but no future owner would easily work it out. Where i'm planning to put it would make it obvious that it was the light fuse and it would be easy to access as well.
If I can run the cable must I run this in the 2.5mm cable used for the ring main or is it ok to run it in the 1mm cable i'm planning to use for the light circuit.
Thanks in advance for your always excellent advice.
